Building An LS1
Old Jan 10, 2004 | 12:12 PM
G2 Racer's Avatar
Default Building An LS1
My buddy wants to build an LS1 from scartch for his S10. I though I'd ask here so I could find out where we could get a block, aftermarket (complete) heads, pistons, cam, rods, etc. Can't be core exchange.
Any help?
Thanks!
Old Jan 10, 2004 | 12:31 PM
crainholio's Avatar
You can look up part#s for the big stuff on www.gmgoodwrench.com if you follow the links to GM Performance Parts.
Might be cheaper to buy a crate LS6 longblock, the part# for it is listed there also.
Old Jan 10, 2004 | 01:24 PM
DONAIMIAN's Avatar
Whats the goals for this truck, any specific times he wants it to run or HP numbers to put out. Are you looking for stock cubes a stroker or what.
Old Jan 10, 2004 | 01:53 PM
ssheets's Avatar
There's junk yard near San Jose CA. that sells LS1/LT1 with MS or A4s. LT1 with tranny and conversion kit are about $3,500 LS1s with trans are about $5k email me at ssheets@ispwest.com if you want info. I've got their number somewhere.
Old Jan 10, 2004 | 01:55 PM
ssheets's Avatar
Just saw your location...might be a bit too far for you?
Old Jan 10, 2004 | 03:06 PM
crainholio's Avatar
By way of junkyards specializing in LS1 engines, I got my '01 LS1 and T56 complete for $4500 or so at http://www.contemporarycorvette.com/ located in Bristol, PA.
Old Jan 10, 2004 | 03:37 PM
DaleMX's Avatar
I bought my 99 LS1 / T56 with 28000 miles for less than 4,000.00 a year ago on ebay. All is well, just get references.
Old Jan 10, 2004 | 06:47 PM
G2 Racer's Avatar
Thanks for all the info guys.
He wants stock cubes, just built a bit so he can boost it.
Old Jan 10, 2004 | 06:49 PM
jrp's Avatar
jrp
SN95 Director
pick up a block off of ebay and build up a forged bottom end sice he wants boost.
Old Jan 10, 2004 | 08:04 PM
Nasty N8's Avatar
We have a set of used 6.0L heads complete. Or we can port them for boost and add new valves. I can get you a block and crank also.
Nate
Old Jan 11, 2004 | 01:26 AM
DONAIMIAN's Avatar
Nate
Id jump on this with a set of eagle rods and the pistons of your choice, should be a mean lil truck.
