Does grinding down ls6 intake ribs make it weak enough to crack?
Old May 10, 2010 | 11:40 PM
Pro_built7's Avatar
Default Does grinding down ls6 intake ribs make it weak enough to crack?
Hey guys,
This weekend I ground down the ribs on my ls6 intake to fit the stock ls1.
I was just wondering if anyone has seen an intake crack or break because of this?
( Not running FI )
Old May 10, 2010 | 11:44 PM
garygnu's Avatar
no !!!!!!!!
Old May 10, 2010 | 11:51 PM
Squirts11's Avatar
Since the ls6 intake swap was the first mod I did, I guess at the time I didn't feel comfortable grinding down the tabs.
Now, I'd have no problem doing it, but I'm glad I bought the ls6 coolant crossover tube/plugs, as they're considered a superior design.
You'll be fine either way.
Old May 10, 2010 | 11:54 PM
Pro_built7's Avatar
ok sweet !
What about on FI applications ?
Old May 11, 2010 | 12:00 AM
99'CajunFirehawk157's Avatar
Thumbs up
Screw Grinding it down! Much easier/quicker and can be neat too to just take a wood chisel and a small hammer and just lightly whack it on an angle where you want the ribs to disappear, nothing to it.
Old May 11, 2010 | 12:14 AM
garygnu's Avatar
thats pushing it .consider a weiand or TBK intake.
Old May 11, 2010 | 05:37 AM
The Alchemist's Avatar
UNDER PRESSURE MOD
The ribs are casting ribs. They are there to keep the intake from shifting during the manufacturing process and are what was used to align the intake when they mated the top to the bottom. Just like the casting tabs on your block, they serve no purpose to the finish peice.
Old May 11, 2010 | 09:43 AM
Pro_built7's Avatar
Ohh now I see, so I could still use my ground down intake if I ever go FI right?
also does anyone know if that bottom plate of the intake serves a purpose? I kind of nicked it with the grinder in a few spots, not bad at all but took maybe
.020 of material off by accident.
Old May 11, 2010 | 01:43 PM
bww3588's Avatar
thats debatable...ive seen the #7 hole get hot because of the lack of coolant flow back there...
personally, id rather grind the ribs down or make my own coolant lines out of AN fittings and some braided line.
Old May 11, 2010 | 01:52 PM
jc98ss's Avatar
+1....chisel works much better....i tried both....funny thing is i didn't even have a chisel so i made one with an old screwdriver and a grinder....worked like a charm
Old May 11, 2010 | 01:57 PM
Z28/2002's Avatar
From: Your girl's back door giving her the long stroke while you're at work
I used the wood chisel on mine also and haven't had any issues with it
Old May 11, 2010 | 02:14 PM
Squirts11's Avatar
Interesting, as that's the first I've heard of that. Good to know.
I guess I would have ended up needing to buy the ls6 lines/plugs anyway, as the FAST 92/92 I'm about to install wouldn't have fit over the ls1 coolant tube, correct?
Old May 11, 2010 | 02:24 PM
1badSS's Avatar
I ground mine down with no problems.
Old May 11, 2010 | 03:09 PM
Thumbs up
thats debatable...ive seen the #7 hole get hot because of the lack of coolant flow back there...personally, id rather grind the ribs down or make my own coolant lines out of AN fittings and some braided line.
Cheaper route is 2ea ls6 front steam tubes, 1ea brass T fitting and 4ft 1/4 fuel line and some hose clamps, works just like original LS1 configuration and no # 7 concerns.
Old May 11, 2010 | 03:16 PM
bww3588's Avatar
agreed, i just get AN happy sometimes.
Old May 11, 2010 | 03:19 PM
jc98ss's Avatar
yep....something about blocking off coolant tubes in an all aluminum motor just didn't seem right to me....definitely knock off the ribs or build it with things like this to flow like it should.
Old May 12, 2010 | 06:19 PM
99T/AMAN's Avatar
yeah i ground mine down 2 years ago to keep the stock coolant tubes and havent had any issues. I did that because i heard of the #7 getting hot also
