Rockers
Old May 11, 2010 | 04:16 PM
blkbird's Avatar
Default Rockers
Has anybody used these and how well do they work????
Competition Cams 1370-16 Pro Magnum Roller Rockers Rocker Arm 16 pc. Rocker Stud 3/8 in. Ratio 1.85 GM GEN III LS1/LS6 Engine
8620 Chromemoly Steel
Three Times Stronger
Less Weight At The Valve
More RPM Valve Train Stability
Larger Trunion
More Needle Bearings
Integral Pushrod Seat
1 Year Limited Warranty
Old May 11, 2010 | 04:34 PM
kinglt-1's Avatar
most are going to tell you to stick with the 1.7's and add the extra lift in the cam. Imo 1.85 rockers are a decent mod for a guy lookin to get a little extra power across the curve from a stock camshaft. Comp makes a few low lift cams designed for high ratio rockers awell, but most aftermarket cams today have really aggressive lobes and anything higher than a 1.7 is not recommended.
Old May 11, 2010 | 04:40 PM
blkbird's Avatar
Yeah, i know all that, just checking to see if anybody has used these. I have the infamous hotcam in my ride and dont want to do another cam swap anytime soon. Once this motor give im going to get bigger cubes but for the meantime i was wanting to bump the lift a little.
Old May 12, 2010 | 01:35 AM
droptopT/A's Avatar
i also have a hotcam and was thinking of the same rockers bump to the top
Old May 12, 2010 | 09:45 AM
KCS's Avatar
KCS
Moderator
Those are the stud mount conversions right?
Rocker ratio debate aside, the cool thing about these is that it's easier to set proper rocker geometry since the rocker doesn't rest on a stand. Just determine the correct length pushrod. Probably not a big deal with the Hotcam, though, since it has relatively low lift, but a nice feature for a higher lift cam.
Old May 12, 2010 | 12:31 PM
Silver408z's Avatar
If you are planning on doing more mods later I would just save the money from the rockers for engine.
