HS roller rocker install.
Old Jan 11, 2004 | 09:47 AM
gojo's Avatar
Default HS roller rocker install.
I'll be installing a new cam with Harland Sharp roller rockers.
Harland Sharp recommends turn from zero lash with roller rockers. The stock rockers require to 1 turn from zero.
There is also the torque setting method, which on our cars Ive seen 22 to 45 lbs. Im confused.
But, since I'll be going with the rollers my feeling is to do the zero lash method.
Any advice on this would be appreciated.
Also, should I worry about having shims available since it will be done on a weekend 60 miles from home.
Old Jan 11, 2004 | 09:53 AM
BergerMan's Avatar
Its not 22-45 ft/lbs its 22-25 ft/lbs. If you were to torque the rocker bolts to 45 ft/lbs you would either strip them out or break them off!!!
Stock rocker arm torque is 22 ft/lbs with 3/4-1 turn from zero lash. Yella Terra recommends 25 ft/lbs with the same lash. I heard that Harland does not ship shims because they are not needed.
Old Jan 11, 2004 | 10:01 AM
gojo's Avatar
http://www.harlandsharp.com/tectips3.htm
So, I would guess if we set up the HS rockers per their TechTips they would torque under 22 lbs.
Old Jan 12, 2004 | 04:26 AM
Blktie8's Avatar
Default comp R
Joe
I would like to get in on this also ,I just can't get a good answer.
Does anyone have the int and exhaust shaft (YT OR HS ) system with COMP R Lifters.
I have .040 difference between the exhaust and intake valve stem.
How can this work without adjustable rockers .
Shims adjust both at the same time ,correct?
One will be loose if the longer valve is the one the shims are set for.
Or if it is done the other way the valve will hang open ?
Old Jan 12, 2004 | 10:51 AM
Nasty N8's Avatar
If you have 2 differant valve stem leangths than you will be needing adjustable rockers.
I haven`t needed any shims yet. Install them per Harlands instructions and you will be OK.
Nate
Old Jan 12, 2004 | 11:13 AM
gojo's Avatar
Nate
What if he uses two different pushrod lengths? I think the valves are off by 40 thousands.
Old Jan 23, 2004 | 09:37 AM
BB's Avatar
BB
Anyone got any answers to this difference in valve measurements? I have the YT and I am going to be putting in Comp R lifters. I wouldn't expect a difference in the measurement. What could cause that if the PR are identical lengths? I would expect And are adjustables rockers the only way to correct this?
I would think you would need to make sure the lifters are bleed all the way down before setting the valve lash. Is that correct?
Old Jan 23, 2004 | 02:05 PM
NataSS Inc's Avatar
I will be doing the HS and the comp R lifters tonight. I will post my results/headaches I ran into when completed.
Old Jan 23, 2004 | 02:37 PM
NataSS Inc's Avatar
Default tech tips vs. LS1 specs
Just thought of this. The HS site tech tips all revolve around the SB chev/ford stuff. But The LS1 is just about a completely different monster. I would almost want to say that you should do it like you were putting in new stock rockers. Since these are a direct replacement for the stocker why would you not follow the same instructions for a stock rocker.
when I had my old cars that had SB motors I always did the "tighten till it stops ticking and then 1/2 turn". That seems to be what HS is recommending on the tech tips. But the LS1 requires specific TQ specs to work properly. I am not saying this would not work on our cars but since these are stock replacements.............see where I am going with this one.
Old Jan 23, 2004 | 02:42 PM
Nasty N8's Avatar
1/2 turn is perfect if you are doing Comp r lifters than I would do about 0-1/4"
Nate
Old Jan 27, 2004 | 07:27 PM
NataSS Inc's Avatar
so you just run them till you can barely turn the push rod and then tighten 1/4 turn. BUT you dont torque them down?
Old Jan 27, 2004 | 07:31 PM
Scalpel's Avatar
Once they barely turn by hand then you see how many turns it takes to TORQUE them to spec
Old Jan 28, 2004 | 11:08 AM
Blktie8's Avatar
Nate
Nate there seems to a lot of confusion on this only adjustable rockers can set the preload for the individual lifters
With shaft rockers they must be set at 22lb ft and with different valve stem heights this might be a problem with comp r lifters because of the close +0 +.010
Preload
Is this what you are saying Nate
John
Old Jan 28, 2004 | 11:32 AM
jmX's Avatar
jmX
Nate was telling you how many turns you should have from 0 lash to "tight". No matter what, you have to hit 22 lb/ft, but if it takes you 3 turns to get there from 0 lash, that is no good!
Old Jan 28, 2004 | 12:47 PM
Nasty N8's Avatar
What JMX said. If it takes more than they need to be shimmed or differant length pushrods.
Nate
