throttle sticking?
Old Jan 12, 2004 | 02:58 AM
avezz28's Avatar
Default throttle sticking?
I hope this belongs in this section...but here goes. I'll be driving down the road and coming to a stop with the clutch in and my rpm's get stuck at like 1700 or so. Then after I come to a stop my rpm's will stay there for a few seconds and then fall back to the normal 800. This is very annoying, has anyone else had this problem?
Old Jan 12, 2004 | 05:29 AM
Slowhawk's Avatar
LS1Tech Sponsor
It's either a vacuum leak or needs some more tuning in that area.
Old Jan 12, 2004 | 01:29 PM
avezz28's Avatar
How would I check for a vacuum leak and what can be done to fix it?
Old Jan 12, 2004 | 05:42 PM
2001CamaroGuy's Avatar
first check that all lines are on the manifold.....if they are, then get some carb cleaner and with the engine running spray some around the surfaces of the manifold and the head, and the TB and manifold. If there is a leak, the engine will suck the carb cleaner in and usually stumble.
Old Jan 12, 2004 | 07:03 PM
emarkay's Avatar
I had a small rock get wedged between the throttle return spring and the stop support.... It freaked me out at 65MPH, and I quickly pulled over and I noticed a slight uneven feel while moving throttle by hand. I lookecd closer and saw that bugger there.
Check for FOD!
