'''''dropped a lifter'''''!!!!!!!!!!! doing cam swap need help!!!!
https://ls1tech.com/forums/generatio...3-install.html
Scroll down to post 13 on page 1. You"ll see the pic where the 2 metal rods are sticking out next to the cam. Once you remove the cam retainer plate, you"ll see the 2 oil galley holes where the dowel rods go. Buy one 5/16 48 inch long rod, cut it in half & thats all you need to hold up the lifters. Remember to remove your rocker arms first, then spin your cam a few times. This will push the lifters up into the lifter trays so you can slide the dowels in. It doesnt have to be metal either, I just bought a wood dowel. Theyre cheaper too & work just as good.
