oil pan clearance!!!
Old May 28, 2010 | 05:07 PM
victor111262's Avatar
Default oil pan clearance!!!
those anybody have oil pan clearance problems cos my swap i got like one inch of clearance. would it be fine or would i need to change the oil pan or is there a way i can get the set up of an ls7
Old May 29, 2010 | 04:44 AM
bump??
Old May 29, 2010 | 08:12 AM
twitchtwice's Avatar
what motor, pan, and car? need more info.
Old May 30, 2010 | 03:12 AM
its a 2001 camaro the swap is a 6.0 from a 2002 silverado 2500 and the oil pan its too low
Old May 30, 2010 | 03:24 AM
jugz ss's Avatar
Use the f-body oil pan and it should be fine
Old May 30, 2010 | 03:37 AM
the thing its that the motor its already in and it really doesn't hit the floor unless they will be a big bump, has not happened yet im just trying to see my options in case it happens
Old May 30, 2010 | 04:01 AM
need4fun2469's Avatar
when people swap in the truck motor they always transfer the ls1 oil pan because of clearance. Take your oil pan off your old engine to the 6.0.
Old May 30, 2010 | 04:03 AM
that oil pan is gone it blew a whole when i blew the engine
Old May 30, 2010 | 03:38 PM
jugz ss's Avatar
Well once something does happen and you hit it on a bump Your options are still to get a f-body pan. But I would just change it now before you get another hole under their from a bump and you end up droping your oil and risk ******* up your motor.
Old May 30, 2010 | 03:40 PM
jugz ss's Avatar
Or you can just donk it out and put some 24's and have no clearance problems at all.
Old May 30, 2010 | 06:10 PM
lol but i was thinking on something like the ls7 no oil pan
Old May 30, 2010 | 11:39 PM
SSANIMAL's Avatar
what you can do if your leaving the truck oil pan in there is get some solid sphon motor mounts they raise your motor like in inch
Old May 30, 2010 | 11:50 PM
do you know where i can get them
Old May 31, 2010 | 01:34 AM
Paint_It_Black's Avatar
Not saying they should or shouldn't be used for this purpose, but here is a link:
http://www.byunspeed.com/product_inf...d6c0a6b86c9465
Old Jun 3, 2010 | 03:23 PM
ss.slp.ls1's Avatar
The spohn solid motor mounts will not be enough. You need to get a LS1 oil pan.
Old Jun 3, 2010 | 03:44 PM
bww3588's Avatar
exactly, there is a reason the oil pans are different.
Old Jun 4, 2010 | 02:10 PM
The trial by error method is not the right one to use.Especially in this case. If you rip or punture the oil pan because of clearance and loose the oil, you will be putting another engine in again.
Old Jun 4, 2010 | 09:39 PM
izzman55's Avatar
did you stroke the motor at all. that clearance would be good for that.
Old Jun 4, 2010 | 11:15 PM
what the hell are you talking about?
Old Jun 5, 2010 | 04:17 AM
ss.slp.ls1's Avatar
LOL, exactly...
