another LM7 swap and noob with ??????S
*i wanna know do i use the truck harness and ecu/m or can i run a camaro harness and ecu or LM7 and ls1 ecu interchangable with the 5.3?
*do i swap injectors to use the camaro harness?
*how much can a 5.3 pump out still being a 5.3?
*is it possible to run a MTI X1 cam
*do i have to change the whole valvetrain or just springs and pushrods?
sorry if im noob status but i wanna get sum 411 before i buy this motor if its worth the 600 then ill do but if it equals more than an ls1 then ima save for a couple months the power im trying to laydown is between 350-380 at the wheels is that too much for a 5.3 or no? im not trying to be the fastes in the world i jus want sum gm horsepower under the hood of my car my lil ka24e is in good shape but it needs to retire i might do a ka-t for another s13 but i want someone to give me some advice on my LM7 idea
i dont want 2.4l nomore
*i wanna know do i use the truck harness and ecu/m or can i run a camaro harness and ecu or LM7 and ls1 ecu interchangable with the 5.3?Either one will work. You will need a tune if you use a LS1 pcm but if you are putting a cam in it will need to be tuned anyway
*do i swap injectors to use the camaro harness? If you are gonna run a cam bigger injectors are a good idea. I sold my stock 28.5 #'s for $50
*how much can a 5.3 pump out still being a 5.3? Your goal of 350rwhp can be met on a stock bottom.
*is it possible to run a MTI X1 cam I would run something a little smaller like a TR224 or 224/228 and mill to bring the CR up as much as possible . A stock 5.3 has 9.5-1 CR so it needs help there.... But yes that MTI X1 will fit
*do i have to change the whole valvetrain or just springs and pushrods?Springs and PR's if you run beehive + retainers/locks if you need doubles
