What would it take to spin stock inards at 7k on a 5.3?
Old Jan 13, 2004 | 02:40 PM
Flyer's Avatar
Default What would it take to spin stock inards at 7k on a 5.3?
What the title says .... could I get away with just a good set of rod bolts?
Old Jan 13, 2004 | 03:05 PM
gator's 99TA's Avatar
i assume you are putting together a head and cam combo that requires to go that high in the rpm band? rod bolts are a good idea. prayer is a better one. no stock lsx rotating assembly will love long at rpms that high. factory specs are too loose for that.
Old Jan 13, 2004 | 04:43 PM
Nasty N8's Avatar
Ya the highest I would rec. is 6800 til you build the bottom end.
Nate
Old Jan 13, 2004 | 04:52 PM
Flyer's Avatar
Nate
Would the rod bolts help out any?
Old Jan 13, 2004 | 05:32 PM
Cal's Avatar
Cal
Yes, ARP rod bolts will help by replacing the weak link. The GM engineer that designed the LS1 said the motor could run all day at 7000 rpm, but oil film thickness at that rpm would cause acelerated wear. In practice many people have gotten away with it, yet other people don't. It must depend on whether you got lucky and got a motor built with the right tolerances from the factory.
Once you upgrade the rod bolts, the next weakest link will probably be the rods, so a set of forged rods would be a good idea as well.
Personally, I would upgrade the valvetrain also with some stiffer push rods, roller tip rockers, and some good valve springs.
Old Jan 13, 2004 | 09:48 PM
TEA Brent's Avatar
I'd do rods bolts, main studs and spin it. That's what we did.
Old Jan 13, 2004 | 10:01 PM
Jammer's Avatar
Rarely have I heard of a need for upgraded rockers.
Old Jan 14, 2004 | 12:15 AM
Spinmonster's Avatar
ATI super-damper.....smoother revs will lessen the need for a tow.
Old Jan 14, 2004 | 12:31 AM
Gary Z's Avatar
Cal probably didn’t mean to but his wording implies that upgrading the valvetrain is optional – it isn’t.
Old Jan 14, 2004 | 01:25 AM
Flyer's Avatar
This is all based on a cam swap. I don't think the 5.3 would make it to 6500 on a stock cam before it started to float.
Do you think 918's would be sufficient with .54 lift?
I'm not real worried about the rockers though ... ya .. they could be changed, but I think the stockers will be OK for a little while.
