Question on G5X3 cam??
Old Jan 13, 2004 | 03:29 PM
BADBOYZ28's Avatar
Default Question on G5X3 cam??
I was considering putting this caminto a 2000 LS1 A4 Camaro. Its got stock internals with motsly all the bolt on's with a NOS DRY 100 shot. What I wanted to know is would this be a good cam to go with and would it still be pretty streetable. Its a dailey driver and Iv heard that its a pretty big cam. Also what kinda gain should I expect from it tuned and all. Right now I'm running a 12.4 @ 110 with 1.7's 60ft.... Any and all opinons & experiances would be greatly appreciated..
Old Jan 13, 2004 | 03:45 PM
jrp's Avatar
jrp
SN95 Director
keep in mind streetable is a relative term. being a daily driver i wouldnt go that big, you'll want a 4k+ stall too since you have an a4. the x3 is a great huge power cam but a4 + daily driving i'd go smaller. what are your bolt ons, you'll want a stout induction and exhuast setup for a cam like that.
Old Jan 13, 2004 | 09:12 PM
pewter99SS's Avatar
might want to look into the X2, it would prolly be a better cam for ya. Also with the X3 you need to replace the lifters because of the massive spring pressure on the comp springs that LG uses.
Old Jan 14, 2004 | 07:54 PM
BADBOYZ28's Avatar
The bolt on I have right now are Vig 3200 stall, 3.42's,SLP long tube headers, HPP3, cutout, whisper lid with mass air, no cats, free mods. If you guys think that cam is to big for my car sicne1)its a A4 and 2) its a daily driver what cam would you guys recomend?? What about a custom grind cam from comp cams?
Old Jan 14, 2004 | 08:07 PM
Z O SICK's Avatar
I also think you will need more stall fior an X-3. I think you will fine with an X-2 or X-1 from LG. Will will need some good tuning in your case being that you are A4. Good luck!
Old Jan 14, 2004 | 08:15 PM
jrp's Avatar
jrp
SN95 Director
depends on your goals, daily driving a4 with 3200 stall i'd stick in the 224-230 range on a 114.
Old Jan 15, 2004 | 06:34 PM
BADBOYZ28's Avatar
what are the specs on the X3? Would there be much of a diffrence between X3 and the X2?
Old Jan 15, 2004 | 06:50 PM
jrp's Avatar
jrp
SN95 Director
official x3 specs arent released from my knowledge, its bigger then the x2 obviously but not big enough to require fly cutting with stock heads.
Old Jan 15, 2004 | 07:00 PM
scalemaster's Avatar
well I'm getting the C2 cam 224/224-581/581 112+4 but I might want something else
if u like I sell u this 1
Old Jan 17, 2004 | 10:36 AM
BADBOYZ28's Avatar
Ya I might be intrested. How much???
