Optimal Cam ???
Old Jun 7, 2010 | 04:34 PM
lt170chevelle's Avatar
Default Optimal Cam ???
I have a 98 Blazer with a stock 5.3. What would roughly be a good cam range for the 5.3 ? Stock converter and manifolds.
Any info on cam selection would be much appreciated.
Old Jun 7, 2010 | 05:33 PM
99Bluz28's Avatar
A 212/218, 112 lsa, would work good.
Old Jun 7, 2010 | 05:36 PM
RibeiroBJJ's Avatar
Mild side...Comp 212/218 Low Lift
Little more agressive...TR 220/220 (2800+ stall recomended)
The Comp 212/218 is probably your best bet with stock stall and makes great torque...and that is what trucks need!
Old Jun 7, 2010 | 05:50 PM
orangeapeel's Avatar
ЯєŧąяĐ Єl¡m¡иąŧøя ™
I would suggest a little larger stall if you were planning on even a mild cam.
Old Jun 7, 2010 | 06:07 PM
ok so what kinda lift we talking about? would around a .550 ish lift be about right or larger?
Old Jun 7, 2010 | 08:02 PM
RibeiroBJJ's Avatar
.550 is good....a tr 220 is 220/550....a 212/218 52x/53x 114lsa would be ideal with stock stall...ALOT of the truck guys do it with great results...just buy it already!
Old Jun 8, 2010 | 05:30 PM
lol ok sounds good ..i am now on the lookout for a used cam of that profile then lol thanks for everyones input
Old Jun 8, 2010 | 05:32 PM
one thing ive been trying to find was some info on a 5.3 that carcraft had done a cam swap only and supposed to had made 90 something hp from the swap! anybody heard or seen this article..i havent had much luck finding it.
 Michael S. Palmer
Old Jun 8, 2010 | 05:34 PM
twitchtwice's Avatar
yeah. i think i know the article. i think thats with some AFR ported heads and the comp thumpr cam. thumpr cam is like 218/230. someone will probably correct me, i dont feel like looking the info up.
Old Jun 8, 2010 | 10:35 PM
99Bluz28's Avatar
EPS has a few 5.3L cams.
http://www.engpwrsys.com/index.php?act=viewCat&catId=15
Old Jun 8, 2010 | 10:40 PM
izzman55's Avatar
a z06 cam would work. not too crazy mild enough
