How much to mill?
Old Jun 8, 2010 | 01:07 PM
ABQ99TA's Avatar
Default How much to mill?
I have mahle pistons with -4cc reliefs with TSPs Torquer 3 and I will be using 799s milled. I was looking at 10.9:1 compression with a 57cc chamber but I was not sure if milling that much would cause any issues. Is it safe to mill heads that much?
Old Jun 8, 2010 | 02:37 PM
Z28/2002's Avatar
From: Your girl's back door giving her the long stroke while you're at work
Call TSP and talk with them, they helped me out a bunch when I was wanting to mill my heads.
Old Jun 8, 2010 | 02:38 PM
Sales4@Texas-Speed's Avatar
LS1TECH & Trucks Sponsor
You can mill the heads that far if you would like, but it will start to kill flow of the head. We will usually go down to a 59cc chamber and then run a .040" thickness gasket to get that kind of compression ratio.
Old Jun 8, 2010 | 09:16 PM
ABQ99TA's Avatar
I think I will need a .045 head gasket from what I'm looking at. As far as I can tell if I am measuring correctly my piston is coming out of the hole .012 +/- 2. I'm not sure I am measuring right or not.
I have my dial indicator set at zero right next to the piston on the block .
Then I move it right over the edge of the middle of the piston and turn it to find my measurement.
Does that sound right or should I be looking at the very center of the piston?
So being that the block has been decked if I can get good quench (32-38) with a 45 or 51 gasket will my compression be the same as a 40 gasket as long as the quench is in that zone?
Thanks for all the help
Old Jun 8, 2010 | 09:18 PM
ABQ99TA's Avatar
PS were can I buy check springs?
