is there a way to know compression after an engine is built
Old Jun 10, 2010 | 10:53 PM
twitchtwice's Avatar
Default is there a way to know compression after an engine is built
i did a heads/cam swap a few weeks ago and was just curious if my compression went up at all. the only changes made that would change compression would be that i put some stock 799 heads on with MLS gaskets.
its no big deal if there is no way to know, i was just curious. thanks in advance
Old Jun 10, 2010 | 11:08 PM
Paint_It_Black's Avatar
You went from a 66.6 cc chamber to a 65 cc chamber, and used the same thickness gaskets. You might have raised your compression by .2
Old Jun 10, 2010 | 11:18 PM
okay cool. my car had the graphite gaskets stock, they werent thicker then the MLS?
Old Jun 10, 2010 | 11:55 PM
Not that I know of.. just the graphites were on earlier years and the mls were later years. Someone can correct me if I'm wrong but the LS1 never changed compression through the years.
Old Jun 11, 2010 | 12:09 AM
im sure your right. im just curious so i know for the future. i mainly got them so that i wouldnt have to clean the block again like i had to this time around
Old Jun 11, 2010 | 12:36 AM
Originally Posted by twitchtwice
im sure your right. im just curious so i know for the future. i mainly got them so that i would have to clean the block again like i had to this time around
I hear you! I hate scraping graphite gaskets off the block.
