help with cam swap
Old Jun 12, 2010 | 03:41 PM
crazygn's Avatar
Default help with cam swap
hey guys i have the cam gear off and was told you can use a 5/16 rod to hold the lifters up. But it just hits the lifters, how do i get the lifters up to push that rod in so it holds the lifters up. I tried to turn the cam but there not that high
Old Jun 12, 2010 | 04:57 PM
Turbosixx's Avatar
You did loosen all the rockers and removed pushrods? If so, the lifters should stay up in the trays once you spin the cam over a few times.
Old Jun 12, 2010 | 07:29 PM
crazygn's Avatar
i still have the pushrods in to see if the lifters stay up. All seem to stay but one.
Old Jun 12, 2010 | 09:17 PM
Turbosixx's Avatar
Maybe try pulling up the lifter with a pen magnet. Then the 5/16 rod should go in?
Old Jun 13, 2010 | 12:28 AM
garygnu's Avatar
remove the rocker arm from the head spin the cam a couple of times ,insert lifter retain rods.
Old Jun 16, 2010 | 07:22 PM
WhiteHawk489's Avatar
i take it its ok to use the old lifters with a cam swap? id think you would have replace them with the cam. im looking to do a cam myself and trying to figure what i need.
