heads/cam questions
Old Jun 15, 2010 | 07:38 PM
getsum27's Avatar
Default heads/cam questions
waiting on my tsp head/cam package to arrive.....
should i go ahead and buy bigger injectors or are the stock ones fine??
i do alot of drag racing and want a clutch that will hold this abuse......what clutch do you guys recommend i get?
Old Jun 15, 2010 | 10:47 PM
orangeapeel's Avatar
ЯєŧąяĐ Єl¡m¡иąŧøя ™
Wait on the injectors until whoever is tuning your car tells you what you are going to need. Chances are you will be maxed out on DC with the stockers, so you will just have to take it easy til you get tuned with a different set.
Trillions of options on the clutch. This isnt the section for that portion of this though, however, I have run about 6 different kinds and liked/hated certain things about them.
Stocker = fail
Ram Powergrip was decent and took a while for it to start failing to absorb abuse.
Centerforce Dual Friction was dookie at holding a cam only setup.
Mcleod adjustable master with Ram Twin Disc was probably my favorite. Allthough heavy the aluminum flywheel offset the extra weight. Smooth engagements under harsh loads.
LS7 Heavy clutch, holds really well. Never slipped...yet.
Spec3+ Decent clutch even after all the bad hype they got for a while. Held pretty well.
Textralia clutches are expensive and people that run them generally like them.
Also check out Monster. I hear they are the bomb!
Old Jun 16, 2010 | 08:47 AM
sujomatt's Avatar
For me.. I don't like to do stuff over again. So I'd check with ur tuner on the injectors and order them prior to ur tuning day..
I have a spec 3+, feels good - not crazy stiff. Holds good power - so you will have room to play if u throw some juice at it.
Old Jun 16, 2010 | 08:49 AM
john563's Avatar
i would just get injectors now
Old Jun 16, 2010 | 09:41 AM
Sales2@Texas-speed's Avatar
LS1Tech Premium Sponsor
Which heads/cam (and therein your power expectations) will help determine which clutch will suite your needs best. We've had tremendous success with the Monster line-up and they offer a warranty that is unheard of!
__________________
Largest Stocking Distributor of LS-x Engines / CHECK OUT OUR NEW WEBSITE!
COMP - FAST - PACESETTER - DIAMOND RACING - EAGLE SPECIALTY PRODUCTS - CALLIES - COMETIC GASKETS
RAM CLUTCHES - MOSER ENGINEERING - KOOK'S HEADERS - ARP - GM BOLTS AND GASKETS - MSD - NGK
POWERBOND - ASP - AND MORE!
Old Jun 16, 2010 | 10:25 AM
Red99TA's Avatar
No need to wait for the tuner - just get some 42# Ford SVO injectors and you'll have PLENTY of room with a H/C/bolt-ons setup. You could go smaller for sure but this would give you room to grow. Just make sure that whatever injectors you get are not installed until your tuner is at your house or your car is at the tuner (don't drive it with bigger injectors and not tuned for them).
Old Jun 16, 2010 | 10:46 AM
john563's Avatar
this is the route I'd go..I bought 42lbers when I bought my heads and cam
Old Jun 16, 2010 | 08:08 PM
getsum27's Avatar
what kind of warranty comes with it??
Old Jun 16, 2010 | 08:30 PM
odarabla's Avatar
I agree with this. Buy the injectors ahead of time that way you have them come time for tuning.
Old Jun 16, 2010 | 09:04 PM
LS12Fast4U's Avatar
Not to thread jack but do the 42lb SVO injectors hook up with are stock wiring harness?
Also i can back up the Monster Stg 3 clutch. Awesome clutch. Will buy one again.
Old Jun 16, 2010 | 09:11 PM
odarabla's Avatar
Yep they sure do. I am using the red top SVO 32lb injecters in my car.
