possibly a stupid question....
Can I take the 383 stroker rotating assembly out of my ls6 and put it in a 6.0 iron block? Thinking about pushing a decent amount of boost and the aluminum block is kinda makin me think twice...any imput would be appreciated. Thanks
You can reuse the crank and the rods but you will need to get new pistons and rings. The 6.0L has a bigger bore than the LS1. Depending on how much you open the bore on the 6.0 block you could have anywhere from a 402ci to a 418ci motor.
sounds interesting. I was asking because i have a friend who wants an aluminum block for the weight advantage, and he has a 6.0 iron block. Wanted to trade a while ago, but i think i will stick with my block, fireball took a alum. block to over 1200 horse, adn im not gonna be anywhere near that for a while, but thanks to both of you for responding.
