Do these heads seem worth it?
Ideally you'd also like to see numbers at .650, .700, and .750 because the short turn on the 853/241 is super tricky and if not done right, they will lose a lot of flow over .600 (I've even seen flow drop at .575) and that's going to hurt your power output because the shape is wrong or an area in the port is too big or too small.
-Matt-
-Matt-
