flycutting pistons for epp blower cam
Old Jun 22, 2010 | 01:15 PM
02LS1ram's Avatar
Default flycutting pistons for epp blower cam
I was wondering if anyone knows if u need to flycut for the epp blower cam. I searched n nothing came up. Cam specs are:
Dur @ .050 232 int 240 exh
Lift .595 int .608 exh
115. Lsa. thanks for everyones input
Old Jun 22, 2010 | 02:00 PM
Sales4@Texas-Speed's Avatar
LS1TECH & Trucks Sponsor
What kind of motor are you putting the cam in? What kind of heads are being used? Give us a little more information and we might be able to give you an answer.
Old Jun 22, 2010 | 03:42 PM
JPH's Avatar
JPH
Dur @ .050 232 intdum 240 exh
I hardly doubt you will.
Old Jun 22, 2010 | 05:08 PM
02LS1ram's Avatar
stock bottom end 346 ls1, either my 241"s or swap for a set of 317"s , but not sure yet
Old Jun 22, 2010 | 08:51 PM
02LS1ram's Avatar
anybody else ??
Old Jun 22, 2010 | 08:54 PM
dschmittie1's Avatar
IT will clear just fine. I have helped put a few cars together with that cam and stock bottom end. One with 241 heads and the other with 317 heads
Old Jun 23, 2010 | 07:53 AM
02LS1ram's Avatar
that's good to hear, do u rember off hand what lengh pushrods r needed
Old Jun 23, 2010 | 08:20 AM
sujomatt's Avatar
Had 317's and the EPP cam - no clearance issues. Had the GM MLS gasket with it too
Stock length PRs
Old Jun 23, 2010 | 08:23 AM
Both I helped with used stock length push rods but you should alway check pre load
Old Jun 23, 2010 | 08:27 AM
1993 z28 f1's Avatar
Hey:
Its not a cookie cutter motor, to many variables to tell you what length pushrod you need. You need a pushrod measuring tool to be exact, Comp sells them, so does other vendors. Also these ? are the things you should be going over with you engine builder, not a forum, that all the info is not given or known for your build.
Dub
When In Doubt Do Without
Old Jun 23, 2010 | 09:40 AM
Since you are using stock heads you should have clearance there. I would still measure to be sure though, every one of these motors is a little different.
Old Jun 23, 2010 | 05:19 PM
02LS1ram's Avatar
Originally Posted by 1993 z28 f1
Hey:
Dub
I just asked to see the pushrods others went w that's all, just bc somebody said the used this length push doesn't mean I'm goin to buy them n slap them in my motor. I'm goin to buy the tool when I take my motor apart. I going to swap my na cam for a fi cam that's all. I never said anything about building a complete motor?
