torque specs
-Arp rod bolts
-head bolts
and im putting valves springs in too...do they need to be a specific measurment?
Thanks,
Ryan
There are plenty of detailed explanations to set up valvetrain and what the measurements mean. You should find the most reliable information as to torque specs and installed heights from the manufacturer who made your parts. They should have been included in the instructions, unless you bought them all used or you didn't bother with them either.
Torque all 15mm bolts to 30lbft in the torque sequence listed in ls1howto.com.
Do a second pass at 50lbft, and finally a 3rd at 70lbft.
Finally install the 5 smaller ARP bolts and torque them to 22lbft.
All of this info is in http://www.ls1howto.com/index.php?article=1
As far as the valvetrain....317 heads, Pac 918 springs, and the cam is 231/226-591/584 115 lsa.
its going to be boosted
Thanks again for all the help guys,
Ryan
