What adj. timing set to use ?
Old Jun 28, 2010 | 12:45 PM
RedHottG2's Avatar
Default What adj. timing set to use ?
I need to know what adj. timing set to use for the Comp Cams camshaft degree kit:
http://www.compperformancegroupstore...Category_Code=
I have decided to not use my LS2 chain and go this rout just to make sure everything is spot on with my H/C/I install. Also if there is anything else needed please let me know. Thanks!
Old Jun 28, 2010 | 01:32 PM
RedHottG2's Avatar
OK I just found this: http://www.ws6project.com/user_stor/...roducts_id=248
Would this be all I need or is there anything better ? Also do I need anything else.
Old Jun 28, 2010 | 03:02 PM
LilJayV10's Avatar
I deleted my posts. I misread your post about you not using the LS2 chain. Sorry.
Old Jun 28, 2010 | 04:28 PM
vettenuts's Avatar
That's the Comp 3153KT, which is made for them by Cloyes (same part number). Cloyes also makes OEM. So, you are getting the Cloyes Hex-adjust with the Renold LS2 chain when you buy that.
