LS1 vs. LS6 Heads?
Old Feb 23, 2003 | 05:15 PM
Jimmyz's Avatar
Default LS1 vs. LS6 Heads?
I have an opportunity to buy a set of 2002 LS6 stock heads. My current LS1 heads are ported and flow 280 CFM In. and 208CFM Ex. @.600. How much more power can I pick up w/the LS6 heads if I have them ported as well? I will keep the current cam (224/228).
Current power level: 408rwhp 397rwtq
Are the LS6 heads worth 25 more hp & tq?
Old Feb 23, 2003 | 09:15 PM
Got Me SOM's Avatar
Default Re: LS1 vs. LS6 Heads?
15-20 more hp is more likely due tot he smaller combustion chamber.
Old Feb 23, 2003 | 09:21 PM
Chad00ws6's Avatar
sup man I think 20 will work for ya.
I thought the LS6 heads had smaller combustion chambers than the LS1's do which would help CR and they flow bwtter too.
Old Feb 23, 2003 | 09:34 PM
Slowhawk's Avatar
LS1Tech Sponsor
There is much power to gain with LS6 Heads if you have the right Head porter do them for you.I had a set of 02 LS6's done with stock 01 valves and got 300cfm at .550 lift.Now he's porting in some 2.02 valves.
