90k miles, time to change oil pump ??
Also, something else I've ran into lately pulling apart higher mileage LS1 F-bodies. Intake/TB gaskets. I've had 2 cars I pulled apart recently with 100K, and when reinstalling with the stock intake/TB gaskets they had vacuum issues until the gaskets were replaced. You can pick up the gaskets at most auto parts store in a Felpro brand and they're pretty cheap. I recommend doing this on ANY 75K+ engine being pulled apart from now on.
same thing with the oil pump. the pump needs to come off to get the chain off so replace both while your there.
Anybody running a cam or heads/cam motor on a stock chain w/90K+ miles is asking for trouble. Seen too many of them break over the years.
+1000
As noted in the quote, the chain is the most important thing that you should focus on & since the chain needs to be done, you should absolutely do the oil pump. Otherwise, the oil pump is a gear pump & shouldn't be an issue really. Maybe, the oil pump spring (fatigue) could use an upgrade to a higher resistance spring, but, why just do the spring when the pump needs to come off to change the spring anyway. So, change the pump & the chain. Upgrade the chain to an LS2 chain. May want to get new sprockets as well, as they do wear which adds to chain slack & can contribute to slight changes in cam timing.
