Heads
Old Jul 7, 2010 | 11:40 PM
ripinLS1's Avatar
Default Heads
thinking about heads dont know which heads to go with I have stock bottom end ms4 cam fast 102/102 12 bolt 411 gears 6speed :215 prc,AFR, trick flows help! thanks.
Old Jul 8, 2010 | 02:52 AM
ShamelessCookie's Avatar
Your choices are limited with the MS4 and stock pistons.
I'm not sure, but I think either Stage 1 LS6 heads or Stage 2.5 5.3 heads could be setup to clear the MS4. Call TSP to be sure.
Old Jul 8, 2010 | 05:26 AM
orangeapeel's Avatar
ЯєŧąяĐ Єl¡m¡иąŧøя ™
TSP can setup most of their heads to "clear". I know they can for the MS3, but I dont know about the 4. Moving this to Internal from External.
*You may want to read through a sticky or two in this section. I can tell you right now asking "What heads?" and not stating what the cars direction is or what power goals you are looking at achieveing is just going to get you a random slop of people stating a certain brand of heads and life goes on. You can't make a post in this section using cliff notes and expect good results. Its just the nature of the beast.
Old Jul 8, 2010 | 08:58 AM
9secondsflat's Avatar
if you have the money get the tfs 215, no other head makes more power accross the curve then a tfs head on a 346-383 engine.....you wont have any p/v issues due to the valve placement in their heads.
Old Jul 8, 2010 | 07:55 PM
supersick99z's Avatar
Depends on your budget!
Old Jul 8, 2010 | 08:47 PM
garygnu's Avatar
check to see if some TFS 220cc cast heads mite fit.don't mill them.you can get them for $1680 from most vendors.
Old Jul 8, 2010 | 09:31 PM
GTOdave's Avatar
hes a friend of mine and hes got a 3k to play around with..what do you guys think is better..
