Cam only LS1??
Old Jan 18, 2004 | 08:14 PM
SMOKIN01TA's Avatar
i would go with the tr224 on a 114 for what you are looking for. it can be tuned to almost a stock sounding idle but you will get some decent gains
Old Jan 18, 2004 | 08:24 PM
99WS6LS1T/A's Avatar
Originally Posted by SSactionLs1
i would never base my decisions off of ONE track time...track conditions make or brake a setup. And i believe the LG5x2 in an m6 got 10.9x as well..
This car has repeatedly went to the track and been consistant, and still sports the 7.5 rear.
Old Jan 18, 2004 | 08:26 PM
jrp's Avatar
jrp
SN95 Director
Originally Posted by SMOKIN01TA
im sure jrp will chime in but i believe its around a 19x/20x or lower
as spec'd by comps
stock 98 trans am cam
duration@.050 198.86 intake 209.25 exhaust
lift .498 intake .497 exhaust
LSA 119.45
stock 02 trans am cam
duration@.050 196.37 intake 208.72 exhaust
lift .464 intake .479 exhaust
LSA 115.92
Old Jan 18, 2004 | 08:27 PM
jrp's Avatar
jrp
SN95 Director
Originally Posted by 5.SLOW
Well from what I have been thinking something like around 221 duration or a little higher is where most people start. What is the stock LS1 cam specifications?
a 221+ will peak higher then the stock limiter.
Old Jan 19, 2004 | 12:20 PM
The Juggernaut's Avatar
I don't want any trouble.
Old Jan 19, 2004 | 04:11 PM
SMOKIN01TA's Avatar
01-z what were your mods on your 11.54 run. cause im going for the record now.
Old Jan 19, 2004 | 04:20 PM
Congrats on the run!!! Definatly worth bragging about.
Old Jan 19, 2004 | 04:29 PM
94form2000z's Avatar
You will need tuning with just about any cam you go with that'll make you power. Seems from your statement you have a misconception of LS1-Edit anyways. It's a good thing when done by the right person. That alone sometimes will net ya 10 - 20 HP. If I were you and wanted to go middle of the road I'd get either a 221 or a 224 duration cam. Make it worth your while. Might as well drop the whole 6200 thing. Your cutting yourself way short of what that STOCK bottom end will hold.
Old Jan 19, 2004 | 04:33 PM
Mod's?
macs,borla,fipk,GMS maf,asp,all the other boltons,suspension.lightweight.
Good luck...IT AIN'T EASY.
Old Jan 19, 2004 | 04:41 PM
IntenseSS's Avatar
I got a 224/581 cam with headers and LITTLE bolt-ons....and it is a daliy driver 6-speed.
I am close to the 400rwhp range with stock heads. Call up a well know sponsor on this board like speed inc....They have done tons of these set ups and will take good care of your needs. Oh yea I love to scare those new cobras to ,,,good luck
Old Jan 19, 2004 | 04:44 PM
IntenseSS's Avatar
Mod's?
Is this through a stock 7.5inch (toy).....If not what gear are you running??
Old Jan 19, 2004 | 05:30 PM
  #32
SMOKIN01TA's Avatar
Mod's?
mainly wanted to know weight tires and gears. thanks
