replacing an oil pump
Old Jul 8, 2010 | 11:34 PM
topdzl's Avatar
Exclamation replacing an oil pump
Hi
What do I need to buy when I replace my oil pump?
I found a nice oil pump, and I know that I need to buy some gaskets but which one and what other parts that I will need to buy to get this job done?
Cheers
Old Jul 9, 2010 | 06:06 AM
LeftySS's Avatar
Front cover gasket, water pump gasket. Would recommend changing front cover seal as well. Depending on milage of the car you might want to replace the timing chain while you are in there. You will need a new crank bolt as well. All I can think of at the moment. FYI-Ls1howto.com has a good write up on changing a cam, but it shows you how to change the oil pump as well.
Old Jul 9, 2010 | 08:45 PM
crazygn's Avatar
go to the dealer and get a new pickup tube o ring , you dont want to do this twice
Old Jul 9, 2010 | 09:35 PM
supersick99z's Avatar
Agreed
Old Jul 12, 2010 | 06:48 AM
topdzl's Avatar
that was really helpful guys, thank you very much
