Balancing
Old Jul 11, 2010 | 05:54 PM
wrea398's Avatar
Default Balancing
I would like to get some advise on who I can have my rotating assembly balanced by in or around the Pittsburgh area. I have new GM crank, Scat H beams and JE pistons. I already have all the rods, pistons and rings done within 1/2 gram. All I need is to submit my numbers to the tech who will balance my crank. I have sent an Eagle crank to Eagle before for balancing where all I sent was the crank and my weight information on the pistons, rings and rods. Any ideas near PGH? Thanks!
Old Jul 11, 2010 | 11:50 PM
N2O-ARMD's Avatar
The shop needs to know more than just weights of the rods and pistons. In order to get a proper bob weight they need to know the weight of the big end, pin, rings, locks, pistons , oil weight. You should should take what you have to a shop and let them get the bob weights. Also take your balancer, and flywheel.
Old Jul 12, 2010 | 10:08 AM
KCS's Avatar
KCS
Moderator
I'm going to assume that we are talking about an LSx based engine, since this is in the Gen III Internals section of an LSx message board. If that is the case, there is no need for the flywheel and balancer when balancing the crank. The LSx engines are internally balanced.
Old Jul 12, 2010 | 11:00 PM
N2O-ARMD's Avatar
Its always a good idea to check the assembly with the balancer and flywheel that's how we check all our rotating assembly's you would be surprised how many are not balanced correctly. You are correct you don't need them but if your getting it balanced have them checked.
Old Jul 13, 2010 | 07:11 AM
wrea398's Avatar
Default Re
Thanks for the advice but I already know the complete info I am required to have. I agree with the sending the FW and balcance, just not mentioned above. I have all of the required weights on a balance sheet (done this a few times before). Included are each piston, ring set, pin, spirolox set, weight of big end, small end, weight of whole rods, oil, bearings, etc. I have all the required information needed to send to the shop for calculating the bobweight. I just need a shop who does it near Pittsburgh. This is all I wanted to know.
Old Jul 13, 2010 | 10:01 AM
KCS's Avatar
KCS
Moderator
How have you determined how far off they were?
