c5 block
Old Jan 19, 2004 | 08:50 AM
Q8sLp's Avatar
Default c5 block
hi evry bady
i whant to change my ls1 camaro block with corvtte block ? what you think
Old Jan 19, 2004 | 09:00 AM
crainholio's Avatar
I think someone else typed up your signature for you.
Old Jan 19, 2004 | 09:12 AM
Q8sLp's Avatar
Default ?
what you men?
Old Jan 19, 2004 | 09:21 AM
Big Stick's Avatar
Originally Posted by Q8sLp
hi evry bady
Why? Are you NEEDING to replace your block? Keep in mind, the LS1 in the f-body is the same as the ls1 in the vette. Unless you're talking about an LS6? In that case there are conflicting opinions as to which is better.
Old Jan 19, 2004 | 10:04 AM
DaleMX's Avatar
CR5 block has a different bore, although all the external components will bolt on to it, including the mounts and transmission.
Old Jan 19, 2004 | 10:42 AM
Big Stick's Avatar
Yes, but if I understand his question, he's wondering if there's any gain by switching to a CORVETTE block, which is the same as the F-body (except LS6 in which case there are minimal differences) A C5-R block is a different ballpark.
