What Cam????
Old Jul 15, 2010 | 03:49 PM
Bad Blue WS6's Avatar
Thanx!!! i will add that one to the list to reasearch..
Old Jul 15, 2010 | 05:24 PM
Minshall's Avatar
Originally Posted by Bad Blue WS6
holy crap,, you mean to tell me that you only have a cam and intake (i dunno what d love is) and your in the 10's? Did that cam call for any flycutting or P to V issues?
Yup mid 10s. I do have some weight taken out of the car though. No fly cutting or p to v issues. I shift the car at 7200 rpm and its still pulling. Dlove is a member on the boards. He does the tuning on my car. LG has put a lot of time and research in there cams. If you look on the cam only list youll see my cam on there a few times along with the MS3. Granite I have a big stall right now, but when i put the cam in I was on the stock stall. The car didnt buck or studder when I was driving at low rpms.
Old Jul 15, 2010 | 05:29 PM
justinj's Avatar
I ran a F13 on stock heads for a long time.. its not a bad setup. think its a little better then the F14.
Old Jul 16, 2010 | 08:54 AM
wow,, thats impressive from a cam only car,, i may have to consider that one some more,, i shyed away due to the price on it.
,, and thats with stock heads..?
Old Jul 16, 2010 | 09:19 AM
RoidedSS's Avatar
Minshall, can you post your cam specs and also a possible dyno curve? i DD mine for the most part and although you say it didn't give you any problems, it would be nice to know where the cam actually comes into play and just how the curve looks in general. also what stall size are you running and what's your race weight?
thanks
that's a nasty time for cam only
Old Jul 16, 2010 | 09:57 AM
LG dosent show the specs on that cam on their site,, but i did see a for sale post for one on here that listed specs as 239/242 649/609 111.5 lsa
But dont quote me on if thats correct or not..
my main question with this is that how come more folks arent running this cam... or am i just not aware of just how many folks are running this cam... id love to get into ,, hell,, 11's would make me happy,,, i just want to retain stock heads for now,, but want the most for my money and still be able to take my kidz out for ice cream in the car without it being a hassle more than a pleasure,, but still be able to whoop some *** if nessacary.
Ive always wanted to cam,, but you know how it goes,, get all the other stuff first, which i do have,, rear and supporting mods for the new power,, which i also now have,, so i think other than more research to be sure im getting what i want,, and $ of course,, im ready to go for it. This will be my first cam install, so im pretty pumped,, just dont wanna jump the gun on what cam im getting...
Old Jul 16, 2010 | 10:23 AM
*02WS6TURK*'s Avatar
Do you have a A4 or M6? Can't remember if you have stated..you should put your mods in a "SIG" to help us out
With bolt-ons and a streetable cam in the 227/230-234 range which is probably the route you would want to go being you have and want to keep stock heads, you should see 12's. Breaking into the 11's isn't going to happen unless you have a A4, stall and you get a good 60ft and traction. Even then I don't see it happening.
Old Jul 16, 2010 | 10:33 AM
Originally Posted by Turbosixx
Call Geoff at EPS, tell him what you're looking to do. He'll spec you the right cam. As posted above in the links, the EPS lobes are making an *** ton of power with beehive springs. Quiet valvetrain too.
Yeah Geoff is a great guy and will help steer you in the right direction. I'm getting my custom grind camshaft from him here sometime in the next couple weeks.
Old Jul 16, 2010 | 10:35 AM
2000 WS6 48000 miles
M6
Spec 3 w billet steel FW
Pro 5.0
SFC
M12 w/4:11's and AL Cover, 31 or 33 splined axles, cant remember
ADJ LCA's
PHB
non- adj TA bar
LS6 intake
SLP Lid
PnP'ed TB
SLP CAI
SLP bellow
EGR!
AIR!
LS6 PCV
SLP LT's
SLP Cats and Y
Magnaflow Catback
thats it,, everything else is stock,, heads are 241's.
Wayne
Old Jul 16, 2010 | 10:37 AM
low to mid 12's are fine for now as well... i have no idea what the car is running as i have never been to a track,,, the original owner (Nate from Nasty Performance) ran it stock with only a shifter at 13.06 at 106.
Old Jul 16, 2010 | 12:02 PM
  #32
Minshall's Avatar
Yes this is with stock heads.
thanks
The cam specs I dont know. LG doesnt let anyone know. There are rumors as to what it is. Ive been told its a 240/244. All i know is its on a 111 LSA. Unfortunatly I dont have a dyno sheet. The car has never seen a dyno. Its been tuned on the street/track. Im running a TH400 with a Circle D 5C 230mm stall. Its a 5K stall. Race weight is right around 3000 with me in it. The car still has full interior.
With the X3 or X4 cam i dont see any reason why you wont go 11s. My buddies wife has a stock Ram Air with a 3500 stall, gears, and long tubes with true duals. The car has been 11.90s in good air. Let me remind you this is with NO cam. THe only weight reduction was a VFN hood and the a/c compressor removed.
Old Jul 16, 2010 | 02:35 PM
  #33
printmanjackson's Avatar
I would talk to someone that really knows what you need. Just surfing this site is just going to get you different cam specs and everyone's opinion.
Call someone like Geoff Skinner at EPS and he will get you exactly what you're looking for. http://www.engpwrsys.com/
There is a list of venders to choose from ------------------------------------>
Old Jul 16, 2010 | 04:28 PM
  #34
RoidedSS's Avatar
Ya, i saw someone put the specs on the G5x3 on one of the pages on this forum. and then he also stated the G5x4 is +2 in duration on both sides. I won't give out the numbers because obviously LG is making a good product with a good amount of research so i'll let everyone dig around. Again nice time on a cam only car (for the most part )
Old Jul 16, 2010 | 05:30 PM
  #35
https://ls1tech.com/forums/generatio...m-too-big.html
Old Jul 16, 2010 | 06:55 PM
  #36
Minshall's Avatar
Thank you. But I'm a little baffled about the "for the most part thing"?
Old Jul 16, 2010 | 07:00 PM
  #37
T-56SLPSS's Avatar
my choice was the tr230 but my machinist recomended the new comp 273lr. its a 223,231dur- .610,.617lft- on a 112lsa. just finished building the rotating assembly and looking to have the motor in sunday. will post results
Old Jul 16, 2010 | 07:01 PM
  #38
T-56SLPSS's Avatar
ill be running it in a 6.0
Old Jul 19, 2010 | 09:41 AM
  #39
Lots of good info and happy folks with high gears and that cam,,, makes me want it even more,,
Thanx! and while im open to suggestions from any vendor,, im looking for folks that are running cams to give me impressions on what they have used, liked, disliked, etc and how i can make my choices based on my set up and goals. ... the main area is in my keeping stock heads,, not milled or anything,, just stock.
Old Jul 19, 2010 | 10:19 AM
  #40
Chrome355z's Avatar
I am running the G5x2, no track times but it's a 232/240 112+4. Ran it with a SS3600 and now a PT4000 and it pulls hard.
Thinking of switching to an EPS 234/246 111+3, but I'll do that with a set of AI 243s...
