320-330 WHP on a 4.8
I just got a set machined down to 54/55 ish cc's, put a 5.3 at roughly 10.5. Requires intake face milling to do it right. .006 for every .010 worked out perfect for our build. We took off .050, but .060 or more can be done. Just match the intake amount.
What rpm range do you use most? I'm guessing you want a large midrange power, which a tighter (108-110) cam will do.
A set of rod capscrews should be included, not much $$ for the peace of mind they deliver.
