Headgasket issues?
Old Aug 2, 2010 | 11:19 PM
Mkos1980's Avatar
Default Headgasket issues?
These may be stupid questions but is there a differance in headgaskets if I have an LQ4 block and 243 heads? I was thinking the stock GM ones for an LQ4. Or do I go for ones for an LS2? Are they even differant?
Old Aug 2, 2010 | 11:35 PM
Rhino's Avatar
Both the 243 and LQ4 are Gen III designs. If you use an LQ4 head gasket you'll be fine. No personal experience, but the LS2 replacement is a different P/N. Something about it has to be different.
Old Aug 3, 2010 | 05:33 PM
Mkos1980's Avatar
Is one better then the other?
Old Aug 3, 2010 | 10:01 PM
madness02's Avatar
I would use the lq4 gasket and make sure its the multi steel type and not the graphite kind.
