lifters
Old Aug 3, 2010 | 09:28 AM
hifi875's Avatar
Default lifters
i am getting ready to install my eps cam and milled 243s on my 5.3. do i need new lifters or ls7 lifters?
Old Aug 3, 2010 | 09:30 AM
Sales2@Texas-speed's Avatar
LS1Tech Premium Sponsor
If you purchase new GM lifters, they are the "LS7" lifters. Even if you buy singles (which is WAY more expensive than buying a full set), they will be the exact same lifter as what comes in the set.
__________________
Largest Stocking Distributor of LS-x Engines / CHECK OUT OUR NEW WEBSITE!
COMP - FAST - PACESETTER - DIAMOND RACING - EAGLE SPECIALTY PRODUCTS - CALLIES - COMETIC GASKETS
RAM CLUTCHES - MOSER ENGINEERING - KOOK'S HEADERS - ARP - GM BOLTS AND GASKETS - MSD - NGK
POWERBOND - ASP - AND MORE!
Old Aug 3, 2010 | 11:14 AM
69_YENKO's Avatar
Yes, new stock replacement lifters and "LS7" lifters are one in the same.
Old Aug 3, 2010 | 12:26 PM
hifi875's Avatar
so does that mean that i need to replace them,or that i can use the ones currently in the motor???
Old Aug 3, 2010 | 05:40 PM
crainholio's Avatar
That's an interesting question to ask, given you haven't even told us the age or mileage of the engine they're in...or anything else that might yield a semi-educated guess as to their useability.
If you're just asking in terms of compatibility and assuming they're mechanically sound, then there's no reason you can't reuse them w/ your new cam.
Old Aug 3, 2010 | 05:45 PM
printmanjackson's Avatar
cam specs
Old Aug 4, 2010 | 09:22 AM
hifi875's Avatar
218/222 .595/.597 on a 111+2, motor was rebuilt prior to me purchasing it, but i have 0 idea on mileage on the lifters
Old Aug 4, 2010 | 09:54 AM
69LT1Bird's Avatar
How many miles on the engine then? This shouldn't be this difficult.
If unknown, for the cost of a set f GM lifters, just replace them.
Old Aug 4, 2010 | 11:35 AM
hifi875's Avatar
i have put a thousand miles on it.
Old Aug 4, 2010 | 12:58 PM
I would put in new lifters on a new cam
Old Aug 4, 2010 | 01:08 PM
sparkwirez06's Avatar
If you have a problem with them later, you'll not to only have to buy lifters, but head gaskets, fluids, ect. + your time.
