Ls6 ticking sometimes
Old Aug 4, 2010 | 02:55 PM
bovi's Avatar
Default Ls6 ticking sometimes
I've installed my LS6 recently in my rx7. SOMETIMES when im cruising on the highway, a ticking sound is starting, it can stay for 30 secs or all the time the car would run. I stop the engine, start it 5 min later, no ticking...I open the hood and listen, it looks like its coming from the intake ( valvetrain under it). The engine is stock by the way.
Any idea? Test i can do or anything?
Thanks
Kevin
Old Aug 4, 2010 | 03:30 PM
Rhino's Avatar
When you're hearing the ticking, what's your oil pressure? How many miles are on it? Is it a bone stock LS6? Have you ever had it apart?
Old Aug 4, 2010 | 03:58 PM
02*C5's Avatar
If its a stock LS6 with 243 heads and LS6 valves you will experience ticking. The valves are very light and the Ls6 is notorious for sounding like a sowing machine regardless of oil or oil pressure.
Old Aug 4, 2010 | 04:06 PM
bovi's Avatar
Its a stock LS6 with headers/intake. Im running full syntec 5w40 racing oil. I dont know my oil pressure yet, i've not plug the gauge. 54k miles on it.
Old Aug 4, 2010 | 09:45 PM
bovi's Avatar
Can it be the O-ring from my pickup tube or something like this?
Old Aug 4, 2010 | 10:33 PM
180ls1's Avatar
get your engine and oil nice and hot then rent a gauge and stick it on there and see what the psi is. You might not be getting sufficient oil to the topend.
Old Nov 20, 2010 | 04:23 PM
bovi's Avatar
What can be the problem if i have low pressure? Oil pump?
Old Nov 20, 2010 | 11:33 PM
garygnu's Avatar
also take into consideration valve train wear and increased clearences.a .010-.015 longer push rod mite help.all that wear can decreace lifter preload.also consider better trunnion bearings.
Old Nov 22, 2010 | 03:05 PM
bovi's Avatar
The motor is not old enough to need new things because of clearance. I guess its the oring from pickup tube or oil pmp.
Old Nov 23, 2010 | 06:42 AM
crainholio's Avatar
What brand and viscosity oil are you running, and what filter?
What does valvetrain noise look like?
Spend $20 at Sears on a mechanic's stethoscope and probe the valve covers, lifter galley cover, front timing cover, etc...you'll get more detail.
Old Nov 23, 2010 | 11:21 AM
bovi's Avatar
Running 10w45 racing oil with a good filter. Looks like a lifter noire or valve from the rear right cylinder. firewall driver side.
Old Nov 23, 2010 | 06:25 PM
garygnu's Avatar
check push rods for straightness.
Old Nov 23, 2010 | 06:36 PM
crainholio's Avatar
That's a pretty odd oil here in the US, where are you located?
Regarding your question about the pickup o-ring or pump, unless these were recently installed *AND* your oil pressure at hot idle is below 30psi, very unlikely they're the cause.
Old Nov 23, 2010 | 09:06 PM
bovi's Avatar
The motor was installed this summer. I've put the LS1 oil pan on the ls6 for the clearance. I've put the ls6 pickup tube o-ring on my ls1 pickup tube. I'll check my oil pressure this week end.
