need some cam help
Old Aug 5, 2010 | 10:49 AM
droptopcamaross's Avatar
Default need some cam help
I have an 02 droptop 6spd daily driver. 20k miles looking to do cam only no heads. I don't want to have to wind it up to 6 grand to get any power I like my torque. I need something that can lug along @ 1500 rpm in 6th gear when it needs to and a thumpin idle would be nice. I was thinking of Tick performance polluter cam. Any suggestions would be helpful. 400 rwhp would be nice . Long tubes, cat back, lid and filter are only other mods . Might do underdrive pully and electric water pump while its apart.
Torque
drivability
thumpin idle is my priority list.
Old Aug 6, 2010 | 10:13 PM
no suggestions ?
Old Aug 6, 2010 | 10:25 PM
garygnu's Avatar
ed curtis street sweeper,check out studderin 10.60.or a tr2224 ,or a Patrick-G custom cam. or comp LSr truck cam,54-455-11 torque
Old Aug 6, 2010 | 10:31 PM
09camaro383's Avatar
The Tick Performance Polluter Cam is big (24x/24x (.61x"/.61x") you will need supporting mods if you want to run that cam like a fast intake 92 or 102 good headers 1 7/8 and a good tuner!! you probably need a cam in the 22*/22* or in the 23*
Old Aug 6, 2010 | 10:55 PM
ok. only have ls6 intake.
Old Aug 6, 2010 | 11:27 PM
BaddBird's Avatar
Torque
drivability
You wont be lugging a Polluter around on 6th gear. You need to look at cams for power under the curve.
garygnu
ed curtis street sweeper,check out studderin 10.60.or a Patrick-G custom cam.
+1 on the Patrick-G or Geoff Skinner (EPS) Maybe the street sweeper HT,Tr230,or something along those lines.
http://www.youtube.com/watch?v=Ce3mJKW8UVw
Old Aug 6, 2010 | 11:42 PM
99Bluz28's Avatar
IMO, you don't want to much duration, stick to the 220-230 range.
FMS- F6-112(226/230,112lsa)
http://www.futralmotorsports.com/fms....asp?pf=1&pg=5
EPS TT3, 224/230, 111lsa
http://www.engpwrsys.com/index.php?a...od&productId=6
Crane Cams Z Series, 228(.600")/ 232(.600"), 112lsa
http://www.ws6project.com/user_stor/...=5c13650a9fb64
Lunati Voodoo, 227(.584")/233(.584"), 113lsa
lunatipower.com
