Best budget LQ9 setup?
I am running this LQ9 in my very lightweight foxbody coupe and the funds are not there right now to do the above setup. For now I need to figure out the cheapest way to get performance out of the LQ9. Right now it is a stocker w/longtubes.
Thanks!
These cams do like a higher comp ratio to help with flow so keep that in mind.
Any cam upgrade will generally require springs, and pushrods, and if you deck the heads, you will have to refigure out PS length anyways. Retainer upgrade if you run anything larger then Beehives which you should be with the cams I mentioned.
Also timing chain, oil pump, gaskets and the other blah, blah, blahs will be needed.
How much is safe with stock pistons
https://ls1tech.com/forums/nitrous-o...rous-info.html
