LS7 Lifters
Old Aug 9, 2010 | 08:15 PM
Racinjason424's Avatar
Default LS7 Lifters
Did GM ever switch over to LS7 Lifters in LS1 motors, or are they just direct replacements for the LS1 lifters now? I have a stock '04 LS1 from a C5 and I'm trying to determine what lifters were stock.
Reason I am asking, is when Patrick G spe'c out my cam, he gave me a formula for calculating the theotretical push-rod length, and he used 7.380 for stock push rod length and added the 2x the difference in the base circle. I had always heard 7.400 was stock length, but I know LS7's require short rods due to the cup sitting up higher.. I know Pat seems to know his stuff, so I thought maybe my '04 motor cam with the LS7 Lifters, hence the shorter push rods? Thanks, Jason.
Old Aug 9, 2010 | 09:33 PM
gearhead1186's Avatar
to my knowledge only the gen 4 motors came with ls7 style lifters from the factory.
Old Aug 9, 2010 | 10:09 PM
flintwrench69's Avatar
The LS7s are direct replacements for our LS1s.
Old Aug 10, 2010 | 08:05 AM
Slash8915's Avatar
I'm running ls7 lifters no problem.
Old Aug 10, 2010 | 08:19 AM
BIG_MIKE2005's Avatar
Yep, the LS7's are now the only stock replacement. You cant even buy original LS1 lifters anymore, GM will sell you the LS7's instead. I have had mine in my combo for 3yrs & about 50k miles, never had a issue & I drive mine daily.
Old Aug 10, 2010 | 08:49 AM
Ethan[ws6]'s Avatar
Just put a set of ls7 lifters in a t/a this weekend. No need to change pushrod length and as far as I've heard 7.400 is the stock length.
Old Aug 10, 2010 | 09:02 AM
That's good to hear! I was expecting to have to go with shorter push rods, with the cup sitting up some .050/.060 higher..?? I will, of course, check with a p/r checker before final assembly. Wouldnt be the end of the world if I had to buy my fourth set of differentn lenght pushrods!
