is it safe to reuse stock block?
Old Aug 9, 2010 | 08:16 PM
Mightymike2000ss's Avatar
From: Home town Clive,IA current town FORT BENNING GEORGIA
Default is it safe to reuse stock block?
well guys this winter i plan on running a 347, mainly because i dont see any reason why id buy anything else as long as my stock block was good enough. it currently has around 60k on it.
i just want to know is it alright to rebuild the stock motor? and how many miles do you typically get out of them? the biggest ill go is 383 is there any problems with that?
Old Aug 9, 2010 | 08:19 PM
LS1-450's Avatar
Yes, if it's not damaged re-use it. 383 is fine, as well.
Old Aug 9, 2010 | 09:23 PM
gearhead1186's Avatar
as long as nothing is wrong with it, ur fine. 383 is just a 347 with a 4" stroke. torque is nice.
Old Aug 9, 2010 | 09:28 PM
FireTA98's Avatar
^^^^x1 Registered User
I don't see why not using it. If there's nothing wrong it can easily handle a 383.
Old Aug 10, 2010 | 04:35 AM
08 848's Avatar
Compare the price of what you need to get done to your block to that of a new one and see if it's still worth it. That's what i would do.
Old Aug 11, 2010 | 06:11 AM
im pretty sure im sticking with the 383 for the simple fact i already have the block, i think im going to run the tsp 383 rotating assembly and a set of afr 205's with maybe and ms4...
Old Aug 11, 2010 | 06:21 AM
orangeapeel's Avatar
ЯєŧąяĐ Єl¡m¡иąŧøя ™
I would personally get a custom cam specced for a 382.
Old Aug 11, 2010 | 07:44 AM
BlackScreaminMachine's Avatar
Internet Mechanic
Great Advice. MS4 generally gets swallowed up with the larger cubic inches and your leaving power possibly on the table.
EPS a sponsor has been making some sick cams as of late. Also good to speak with is Vengence or even Rapid Motorsports.
SOMbitch's Avatar
You might come out cheaper buing an assembled forged shortblock from a sponsor and selling your old bock.....
Old Aug 11, 2010 | 08:01 PM
does anyone no if it would be a good idea to run my prc 5.3 heads with a 383 and the ms3? the cam and heads have less than 10k miles on it i was thinking i could just send the heads off to be polished and milled, and try and keep the same cam unless i can get an ms4 in there but im not sure about the pistons tho...
Old Aug 11, 2010 | 10:27 PM
ЯєŧąяĐ Єl¡m¡иąŧøя ™
Again, my thought on this would be to sell both and then replace with parts made for a 4".
Old Aug 12, 2010 | 01:18 PM
SOMbitch's Avatar
The 383 is a 3.9 bore so you will be fine. codered2000ss on here makes 470+ with that combo and a MS4 and runs high tens full weight........
Old Aug 12, 2010 | 03:40 PM
Rise of the Phoenix's Avatar
So you can build a 383 stroker motor using the stock block?
