Oil pressure problems?
Old Aug 10, 2010 | 11:42 PM
98LS1auto's Avatar
Default Oil pressure problems?
Guys I bought a used 383 long block. Motor is now installed. Tuner called me today and the oil pressure seems really low. Motor has normal oil pressure when its cold and first cranked up. But he said he was driving it and the water temp was up to about 225-230 and at 2000rpm the oil pressure was like 20lbs. That sounds way low to me. He said that was within spec. But he recommended I have the guys that did the install pull the oil filter and cut it in half and inspect it to make sure nothing bad is going on with the motor.
It seems way off to me. I mean my 120,000 stock motor idles at like 38lbs when its warmed up and hot. Even on real hot days with the ac on. To me it sounds like the bearings are shot or on the way out. What do you guys think might be the problem with it? Plus I really surprised at how hot the motor is running. Before with my stock motor on really hot days with the ac on it would never go over 190 degrees. So I am perplexed as to why this motor is running so much hotter. I know its a stroker but I would not think it would make that much difference.
So what do you guys think the problem may be here? Any ideas appreciated.
Old Aug 10, 2010 | 11:49 PM
cherryelky305's Avatar
factory specs call for about 10 psi hot idle (actually less)
being a 383, it depends who built the motor and what specs they used for the bearings and what oil it was suppose to run on.
It could be fine, or it could be bad depending on the builder.
the temps do seem out of wack, so make sure the cooling system is working good. beyond that you really need to know if the motor was designed for electric fans or a clutch fan, and what temp thermostat is in it.
we really need more information what car is it in, carbed or FI? who the builder is, who the tuner is. it all matters.
Old Aug 11, 2010 | 12:01 AM
98LS1auto's Avatar
Its a 383 LS1. Its in my 98 Z28. Cooling system is the exact same as what I had in the stock motor except I had the shop put a new water pump on it. Same coolant, same factory electric fans, same thermostat, which should be a stock thermostat.
I don't know the builder and I'm pretty certain the guy I bought it from does not know the builder. He got it used from someone. But the guy I got it from has a good reputation on here. I'm not going to mention any names. That would not be appropriate right now. I mean I took the gamble on buying a used motor. I knew it did not come with any type of warranty when I bought it. Oh and its fuel injected like normal.
Old Aug 11, 2010 | 08:54 AM
nysbadmk8's Avatar
20psi at 2k rpm is low. Pinched o-ring... Or your bleeding off pressure internally
Old Aug 11, 2010 | 09:03 AM
1SLwLS1's Avatar
If you are utilizing the stock pump or a pump that flows like stock, and the 383 has average main and rod clearances of ~0.0025" then this is normal, you would need a high volume to bring it up. The stock clearances of 0.001" give it really high pressure. You do not need high pressure, as long as you are 45-50 @ WOT, you're fine. Try and follow the paper trail and find out your clearances as well as what pump you are using. Also, what oil?
Old Aug 12, 2010 | 12:01 AM
98LS1auto's Avatar
The shop is just going to pull the motor out and disassemble it and go through everything. Its the only way to be absolutely sure. They don't want to put anymore stress on the motor because they are worried it will spin a bearing. The oil looks fine and the filter shows no metal. But I agree with them that it is not worth taking a chance on and doing some real damage to the motor.
One other thing about the cooling issue. The tuner said when you crank the car up it seems to get up to operating temp very rapidly. Instead of rising slowly like a car would normally do. The shop said it sounded like a flow problem. Could very well be a problem with the new water pump I had put on it. Even though its new it could still be faulty. I guess I will know more after the motor is gone through and back together.
Old Aug 12, 2010 | 07:55 AM
1SLwLS1's Avatar
Sounds more like an air problem. The thermostat is closed under cold start up conditions. I had this problem when I first cranked up the 408, got hot, quick! I found a better way of refilling the entire engine/radiator, from a site I cannot remember, to get all the air out on first start up. Then it is just minimal top-off to the radiator. Take the rubber hose off the coolant crossover, the highest point in the cooling system, and lay it on top of the throttle body. Slowly add coolant to the radiator. When coolant begins flowing out of the crossover, the engine should be mostly full of coolant. Then just plug it up, leave off the radiator cap, crank it up and top off as necessary.
