I need a part number
Old Aug 13, 2010 | 05:44 PM
jetaws6's Avatar
Default I need a part number
I picked up my new cam bearings today from gm and the parts guy gave me 4 number 2 bearings. He told me that 1,2,4,5 are all the same. I didn't believe him and he showed me that they were all under the same part number. Is he right or do any of you guys know the part number for 1 and 5 because I almost positive they should be different.
Old Aug 14, 2010 | 08:52 AM
crainholio's Avatar
LS1s use same size cam bearings, unlike Gen 1 & 2 SBCs.
Old Aug 15, 2010 | 12:53 PM
1FastBrick's Avatar
Thats not true. 1 and 5 have larger bores in the block then 2-4 you need to use the correct ones for the correct year block. Not sure why The OP is buying them from GM. I am sure they are cheap enough but You can get a set from a company like durabond for around $20-$25
An 07-up L92 Block is different. #1,#5 are the same 89018068. #2,#4 are the same 89018069. #3 is on its own 89018070
SDPC Sales the standard durabond cam bearings for ls1 for $21.95
http://sdparts.com/details/dura-bond/ch-10
Make sure you call because in 03-04 the blocks use a different size and the part number changes from ch-10 to ch-23
Old Aug 15, 2010 | 02:51 PM
crainholio's Avatar
Brain fart, thanks for the correction!
Old Aug 15, 2010 | 03:31 PM
jetaws6's Avatar
I got a friend that works at gm and he can get the whole set for 15 bucks but I just need the parts guy to get his head out of his *** now
