Gaps between cylinder liners and block?
Old Aug 14, 2010 | 09:58 PM
crainholio's Avatar
Default Gaps between cylinder liners and block?
I picked up a used LS1 longblock from a 2001 C5, block is an LS6 casting.
I removed and sold the 241 heads, and was cleaning the deck surface today when I noticed cylinders 2 and 4 have small gaps between the iron cylinder liners and the aluminum block. Pics are attached.
Is this a problem?
The engine has <36K on it, heads were never off, the bores are perfect and still showing crosshatch. That's carbon reflection showing on the bore, BTW.
Attached Thumbnails Gaps between cylinder liners and block?-ls6_block_1.jpg   Gaps between cylinder liners and block?-ls6_block_2.jpg
Old Aug 16, 2010 | 05:22 AM
butler's Avatar
My block is the same. no problems.
Old Aug 16, 2010 | 08:03 AM
Steve Gunn's Avatar
Looks like casting.
