Lifter Preload Question
Old Aug 15, 2010 | 09:06 PM
Ls1ChevyII1963's Avatar
Default Lifter Preload Question
Trying to chase down a low vacuum/surging issue at lower rpms and was wondering if the previous owner put too long of pushrods say .050 out of spec.
Would that be enough to cause the motor to not be able to create enough vacuum?
Old Aug 16, 2010 | 04:39 AM
Adrenaline_Z's Avatar
Quite possible. Excessive pre-load causes the symptoms you describe.
Best thing is to pop off a valve-cover and measure the pre-load before
swapping push-rods.
Old Aug 16, 2010 | 06:36 AM
swapping push-rods.
Yeah thats what I'm doing tonight. I know the car has ls7 lifters and I know the heads have been milled but when I checked the pushrods they're 7.425's.
Old Aug 16, 2010 | 07:00 AM
outkast6991's Avatar
my motor is slightly milled 243's with ls6 valves, ls7 lifters, and 7.350's gave me just under.070 preload. motor is dead quite too
Old Aug 20, 2010 | 03:35 PM
Exidous's Avatar
I believe the LS7 Lifters are about .050" taller in the cup than a LS1 and combined with milled heads I'd say that a 7.350" would be a LOT closer to what you need than 7.425". I use 7.425" on unmilled 5.3L heads with stock lifters. It is the base circle of the cam I'm using that causes the extra .025" needed over stock.
But in the end you MUST measure yourself. A CompCam preload checker from Jegs cost me a whole $11.99 each.
Old Aug 20, 2010 | 04:06 PM
Gary Z's Avatar
Originally Posted by Ls1ChevyII1963
Trying to chase down a low vacuum/surging issue at lower rpms and was wondering if the previous owner put too long of pushrods say .050 out of spec. Would that be enough to cause the motor to not be able to create enough vacuum?
Very unlikely. In order to cause low vacuum, lifter preload would need to bottom-out the lifter and prevent the valve (or valves) from fully closing. Preload needs to be more than 0.050 off to do that.
