243 heads
Old Aug 22, 2010 | 10:36 AM
jrz28's Avatar
Default 243 heads
How much difference from a stock 243 head from a stage 3 243 head? Just want to know whats the hp difference is.
Old Aug 22, 2010 | 11:58 AM
garygnu's Avatar
maybe 20 hp.you need a 4" bore to run most stage 3 243s heads because of valve size.
Old Aug 22, 2010 | 04:05 PM
180ls1's Avatar
agreed, 20ish horsepower is a good generalization.
The gain in power depends a lot on who is doing it the work on them though and how much time they invest.
Old Aug 22, 2010 | 11:43 PM
orangeapeel's Avatar
ЯєŧąяĐ Єlˇmˇиąŧřя ™
Moving from External to Internal III.
Old Aug 23, 2010 | 02:20 AM
Camaro ss 2001's Avatar
if u r stock motor use 2.5 stage heads
Old Aug 23, 2010 | 08:52 AM
incbed's Avatar
JRz28 I have a stock bore LS1 and 243's with 2.055 intake valves and have no issues.
Old Aug 23, 2010 | 05:04 PM
v1gray's Avatar
He may have no clearance issues, but the cylinder is shrouding the valve.
Old Aug 24, 2010 | 08:33 AM
incbed's Avatar
LubeLizard,,, So I guess the the Impala and truck 5.3 engines that come with 243 heads from the factory are having valve shrouding problems also because they have a 3.78 bore with 2.00 intake valves.
I guess the 20 extra horsepower the 5.3 engines picked up going to the 243 heads with 2.00 intake valves is thanks to valve shrouding.
