383 and stock windage tray?
Old Aug 25, 2010 | 09:55 PM
00 black ss's Avatar
Default 383 and stock windage tray?
i just torqued the windage tray down and it looks like its close to hitting the rods/rodbolts. does the stock windage tray clear a ls 383 with a 4.00 crank? or will it need to be modified?
Old Aug 25, 2010 | 10:05 PM
jabird's Avatar
You will have to modify it or use washers so it will clear
Old Aug 25, 2010 | 10:59 PM
89L98T56's Avatar
If you have ARP rod bolts like I do, they will just barely hit the tray. I used two flat washers on all the studs underneath the tray and it worked perfectly.
Old Aug 25, 2010 | 11:05 PM
just confirmed they hit. gotta run and get 2 washers tomorrow. then finish building my motor
Old Aug 26, 2010 | 09:19 AM
89L98T56's Avatar
Good luck!
Old Aug 26, 2010 | 01:49 PM
Jon@Texas-Speed's Avatar
Remember it is 2 washers PER STUD not just 2 washers. Make sure you get the oil pump pick up tube installed correctly in the pump when you put it on. Spacing the tray down can cause it to pinch the o-ring if you aren't careful.
Jon
