Another cam Q?
Old Aug 27, 2010 | 02:10 PM
h8tulooze's Avatar
Default Another cam Q?
Im still looking for a cam for my LS1 motor.
RPM range 1200-1500 through 6500.
Mild ported 243 head, no mill
Vic Jr 750DP
2800 Car, 700R 12 bolt 3.73
Thanks
Old Aug 27, 2010 | 03:59 PM
Mike@ZMS's Avatar
Check out our Stage 3 cam. We are so confident in how well it performs that we are even offering a money back guarantee to LS1tech members.
http://www.zenithmotorsports.com/zmsstage3camshaft.aspx
The RPM range is right at what your looking for, it makes excellent power, has a very good torque curve and though I doubt you will care much, the cam is efficient enough to still see 25mpg on M6 F-Bodies.
Old Aug 27, 2010 | 09:05 PM
h8tulooze's Avatar
This looks like a good one.
COMP Cams 54-424-11
Cam Style Hydraulic roller tappet
Basic Operating RPM Range 1,500-6,800
Intake Duration at 050 inch Lift 212
Exhaust Duration at 050 inch Lift 218
Duration at 050 inch Lift 212 int./218 exh.
Advertised Intake Duration 265
Advertised Exhaust Duration 271
Advertised Duration 265 int./271 exh.
Intake Valve Lift with Factory Rocker Arm Ratio 0.558 in.
Exhaust Valve Lift with Factory Rocker Arm Ratio 0.563 in.
Valve Lift with Factory Rocker Arm Ratio 0.558 int./0.563 exh.
Lobe Separation (degrees) 115
Computer-Controlled Compatible No
Grind Number LS1 XR265HR-15
Old Aug 28, 2010 | 10:53 AM
garygnu's Avatar
tr224 ,or comp 54-455-11 LSr cam.
