Internal engine - tool quest
Thanks,
D
https://ls1tech.com/forums/generatio...-am-build.html
As for the roloc disk, if you've never used one I would advise AGAINST using this tool. If you're not careful you will dig into the block and then you just bought yourself a teardown/rebuild.
Don't know about your coolant but GM uses coolant tabs in their engines straight from the factory.Causes the dexcool to look like brown chunky gunk... I've never seen it look milky though unless mixed w/oil.
