Help diagnosing trans/clutch issue???
Old Aug 29, 2010 | 07:38 PM
mustangh8tr's Avatar
Default Help diagnosing trans/clutch issue???
I've had my 99 z28 6spd camaro for 2 years there's only one problem. After I drive the car hard a few times my clutch pedal stays near the floor I cannot get my car in gear for a little and I have to pump the pedal to return it to normal. We tried bleeding the clutch and replacing the slave cylinder but it didn't help. Any ideas???
Old Aug 29, 2010 | 07:54 PM
KRAZY K 2000 TA's Avatar
Adjustable master from TICK!
Old Aug 29, 2010 | 07:57 PM
BlackScreaminMachine's Avatar
Internet Mechanic
Try the manual section.
You need a new slave cyl, get a 01+ GM unit, also a Tick Master cyl. POSSIBLELY a new clutch if the Pressure Plate is dead but sounds like 99% hydraulic issues.
