upraded pushrods
Subscribe
Sep 2, 2010 | 06:57 AM
I did some research and found chromemoly pushrods. My question is are these push rods hydrualic or do I have to switch everything to solid setup?
here is the link to the pushrods:
http://www.maperformance.com/comp-ca...s-7955-16.html
Reply 0
Sep 2, 2010 | 07:01 AM
They are just thicker/stiffer pushrods since the stockers are weak, has nothing to do with a solid setup.
Reply 0
Sep 2, 2010 | 07:39 AM
Yup, just better material and thicker walls to make them stiffer. They will drop right in, pushrods are the very first thing I swap in every motor I work on. The stock pushrods bend too easily.
Comp also makes a .105" wall version too, I run the .105" wall myself. The ones you linked to are .080" wall
Reply 0
Sep 2, 2010 | 09:22 AM
sweet, I wanted to make sure since the actual text did not specify. I will upgrade them since everything else but rockers is upgraded.
On that point do rocker upgrades depend specifically on the cam and springs you are running? I do not have a cam yet but am running the 26921 dual comp springs.
Reply 0
Sep 2, 2010 | 10:06 AM
For GM style heads, the stock rockers are usually the best. Look up the trunion upgrade for them if you are going to rev over 6400-6500rpm for stability and safety.
Stay away from harland sharps. The yella terra ultralights are real good but have recently had a production fault causing a few of them to break.
Reply 0
Sep 2, 2010 | 06:14 PM
Yup, upgrade your stock rockers with Comps trunnion kit. I just did it to mine not too long ago. Its only $135 too. (#13702-KIT)
Reply 0
Sep 2, 2010 | 07:39 PM
Quote: sweet, I wanted to make sure since the actual text did not specify. I will upgrade them since everything else but rockers is upgraded.
Those are pretty stout, I would personally move up in OD. Thickness doesn't buy much with regards to stiffness.
Reply 0
Sep 2, 2010 | 07:52 PM
Are you M6 or A4? I know a lot of guys who don't run chromo on M6 because if you miss a shift your valve could end up hitting the piston..I'd rather have a push rod bend
Reply 0
Subscribe
