Do I need to mill my heads?
Thanks for any advice,
Nate
I just had to ask this question because I will be installing an X2 cam come the end of February or the beginning of March. I knew that if I had to mill my heads it might pose a problem for P/V clearance, and then I would have had to alter my pistons... I haven't had any problems with my heads, actually I'm very pleased with them; I just can't wait to take advantage of them with LG's cam.
Again thanks,
Nate
You indicated the head sealing surface but in this sentence refer to the valve hitting the piston. Not sure exactly where the damage is but apparently the sealing surface?
If only the head gasket sealing surface is damage I would run a leak down test. If it seals then it should be fine.
