looks like full rebuild time
so i took the filter off and cut it open and heres what i found.
the filter was plugged almost solid with particulate. so i pulled the lifters from the left bank. heres the # 7 cylinder lifters, major scuffing on them.
it just did a cam, lifter , timing chain , oil pump install on it. im thinking i installed the oilpump internals backwards and it ate up the inside of the pump. i have to pull the rest apart yet and see what else is damaged. i can only hope that the crank and rods are ok. so at least it wont be too expensive to rebuild the bottom.
