ls7 cam in a 6.0
the cam i have already that came out of a friends 2006 z06. so i have the cam and have to order springs anyway. is it worth the hassle of having to change the front cover . doing the timing gear swap and extending the wires for the cam sensor from the back of the motor to the front? or would i be better off just ordering a custom cam?
LS7 is designed around LS7 heads - intake/exhaust split is different.
Speed Inc TU1 or TU2 for turbo setup.
Might save your money and get a regular 204/218 Z06 cam or a used cam similar to a Speed inc cam. Just in case you over do it on the stock bottom...
