Antifreeze Change
Old Sep 8, 2010 | 07:13 AM
02 CamaroSS's Avatar
Default Antifreeze Change
Are the gen3 family of engines like the gen1 when It comes to having a plug just above the oil pan rail on each side used to drain the block? If not, how do u drain the coolant from the block? Thanks.
Old Sep 8, 2010 | 09:23 AM
BlackScreaminMachine's Avatar
Internet Mechanic
Last time I checked it does not have provisions. IF your changing fluid over, just do it via the radiator while the engine is running. On a Vette or Fbody, thats the way to do it.
Old Sep 8, 2010 | 10:04 AM
I found on the net it does have a plug on the driver and passenger side to drain the block.
Old Sep 8, 2010 | 12:27 PM
EricD's Avatar
Yes there are two on each side of the block at opposite ends and one of them is for a block heater i believe because it is very big , Eric
Old Sep 8, 2010 | 12:41 PM
that's good to know because i only thought there was 1 on each side
Old Sep 8, 2010 | 08:19 PM
EricD's Avatar
My mistake there is only one on each side of the block at opposite ends, Eric
